Carb BOOTS still sucking air after tightening. easy fix?
Discussion in 'Mechanics Garage' started by anarchy13, Mar 23, 2011.
  1. anarchy13
    anarchy13 New Member
    Germany
    The 4 rubber boots that connect my carb to my motor im pretty sure are leakiing altho they look good. i tightened em down as tight as they will go. anyone know a way to seal em without removing the carb?
  2. mstakern
    mstakern New Member
    Not aware of an on the bike fix, but for the price just get new boots.
  3. squirrelman
    Often there are "limiters"--small collars that fit around the screw between clamp sides--and they can be removed for another turn or two...........but i don't think that's your problem.
    I'm guessing that maybe carbs are not fully seated into boots.
  4. anarchy13
    Germany
    U guys know some good websites to order parts from? Ebay dont have what i need. I tried prying the boots in as i could. They are still not sealing.
  5. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
  6. malaguchi
    malaguchi New Member
    motogrid(dot)com great schematics . can at least get the correct part # prices are good but watch the s & h. click on oem then motorcycle then honda then the model pulldown menu should appear. Its an eye opener as to how many models there are.
  7. betarace
    betarace New Member
    Middleburg, VA
    check the other thread you started on the same topic, I put in about 6-8 links
