cant get the cam chain right
Discussion in 'Mechanics Garage' started by dejapong, Jun 25, 2006.
  1. dejapong
    dejapong New Member
    Help Guys!
    So I have an 86 VF500f. I replaced the valves on the front cylinders and I cant seem to get the cam alignment right. I have a Clymer manual but its fairly cryptic.
    Once I put the whole thing back together, I seems to be getting good compression, and the bike is running but not very well. There is a loud clacking noise coming from the front cylinders.
    This is what I do. I line up the T1 mark on the alternator rotor/starter cover. This is the TDC for the rear no 1 cylinder. Then, I align the cam sprocket markings with the top of the cylinder wall.
    If anyone can help me out it would be so much appreciated!
    http://thebettaworks.com/a.jpg
    http://thebettaworks.com/b.jpg
  2. KonradM
    KonradM New Member
    Did you ever figure out how to get this fixed?
    I have the same problem. I over-reved the bike and my valve bent so I replaced the valve and tried to time the bike acording to the marks. I got the rear cylinders timed but the front one's don't time.
    If you have any ideas.
