Cant get fuel passed pet cock
Discussion in 'General VFR Discussions' started by Dragon66, Aug 9, 2012.
  1. Dragon66
    Dragon66 New Member
    Austin Tx
    I have all vacuum lines hooked up,fuel in tank,pet cock on res position but it only pulls very little fuel into the line when I remove it to see if any fuel is getting into the line but its not enough to feed the carbs and keep them going. Pet cock was cleaned and all rubber diaphrams look good, no rips or tares. fuel level is good, just over the pet cock level. Any ideas. Am I missing something...gravity feed no fuel pump..thanxs for any input
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Sounds like a personal problem bud! :redface: sorry couldn't resest.
    Is there a little screen filter in the tank that may be clogged?
  3. taylor65
    taylor65 New Member
    florence, al.
    Is the gas cap venting? Try opening the gas cap and see how it flows
  4. michaels214
    michaels214 New Member
    Waikoloa, Hi USA
    I just had this problem on a Hawk gt im fixing up. I flushed the tank with half water, half vinegar - letting it soak for a day. And I also replaced the in tank filter/screen that MrSleep speaks of. This is with a mikuni vacuum pump - and the fuel lines were mostly air and not enough fuel. The bike could idle ok but under a higher revv it would want to die out. After the flush and new screen the lines are now full of fuel and I can revv it and it wont want to cut out. I know different bike but seems to be the same kind of problem.
  5. Dragon66
    Dragon66 New Member
    Austin Tx
    Cleaned and flushed, tank, pet cock w/screen and diaphrams,vents.
    Its an 86 Cali. model and all vacuum lines are hooked up even the vent line from the fuel tank to the canisters.
    When I try to start it. I get gas in the line but not enough to flood the line to start.. What's up w that? Any ideas?
  6. TOE CUTTER
    There are what look like two ports for vacuum but only one will work, easy to mix up, are you sure you have the proper port on the petcock ported to vacuum?
  7. Dragon66
    Dragon66 New Member
    Austin Tx
    With the tank on the bike I can see the pet cock. I have the vacuum line on the valve closest to me. Is this correct?
  8. Dragon66
    Dragon66 New Member
    Austin Tx
    Found it!!!No spark to cdi units..MF kill switch...a little bit of dielectic grease and she started right up.....Thanxs for all the responses...
  9. Scubalong
    Cooooooooooool now go ride her.
  10. soloii-74
    soloii-74 New Member
    Middle Georgia
    So you are getting fuel past your petcock? :wink: :tongue: :potstir:
    Good to hear you got it running.
    Now like long said.... Time to ride! :thumbsup:
