cant get carbs off
Discussion in 'Mechanics Garage' started by trouble1, Aug 7, 2011.
  1. trouble1
    trouble1 New Member
    trying to pull the carbs off my 86 vfr 700. loosend the bands but still cant pull them.
    Want to make sure i'm not missing anything before i start pulling too hard.
    Loosen clamps on both sides, heat gun softens rubber, work on rears first, useful pry points between carb tops and valve cover.
    And, DON'T remove alloy bottom of airbox from the carb assembly !!!!!!
  3. stewartj239
    stewartj239 Member
    Syracuse, NY
    I think this is the most important piece of advice. Do not remove it and you can actually use it as leverage for rocking the carbs out.
  4. TOE CUTTER
    Wow.......maybe the single most important bit of advise that can be given with theses bikes.
