Can't figure out why my Radiator fan won't kick on
Discussion in 'Mechanics Garage' started by Indy_ridah, Oct 25, 2009.
  1. Indy_ridah
    Indy_ridah New Member
    I have done just about everything I can think of and I have no idea what else to do..
    I checked the fan fuses, they are good. I had the fan motor replaced..that didn't work...and I even changed out the fan switch..still nothing.
    What can i possibly be missing? Each time i changed something i'd let the bike run to see if it would actually kick on, but it never did even at 245..
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Check for broken or loose wires. Does the fan turn on it you hook it directly to the battery?
    Regards,
    Rollin
  3. squirrelman
    Possibly a bad ground. The fan motor shound be grounded (green wire) to the radiator. Check that the 2 wire plug from fan is attached to wiring harness.
    You could try adding an additional wire from chassis to fan shroud or to radiator.
    You know that touching the black wire to thermoswitch to ground should activate the fan ( key on ).
  4. VFess
    VFess New Member
    Portland OR
    ditto what they said, with pics.
  5. Indy_ridah
    Ok..i will check what you guys suggested..thanks alot..
    and hopefully I can get it working again.
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    how about the relay?
  7. squirrelman
    relay??
    no relay really.
  8. steven113
    steven113 New Member
    Pensacola FL
    Did you check to make sure the shroud around the fan is not bent and jamming the blades stopping it from rotating(it happened to me)?
