Can you remove the FPR without taking off the fuel rail?
Discussion in 'Mechanics Garage' started by TNRabbit, Jun 3, 2014.
  1. TNRabbit
    TNRabbit New Member
    Woodford, VA
    In the middle of replacing my Fuel Pressure Regulator (FPR) & I'm stuck. Can't get it off as is, & I'm wondering if any one has figured out a way to replace it without removing the fuel rail. I had discovered a way to do this on other vehicles, but it doesn't look possible here as the starter valve body is in the way:
    Also, has any other poor unlucky b@st@ard broken off this nipple that controls the flapper? Fixes?
    Removed this POS PAIR Valve while I was in there:
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Epoxied the nipple back in place; the epoxy package says "not recommended for applications over 200 degrees"....hope that won't be an issue~
    I took OUT the idle adjustment screw & was able to bend the fuel nipple on the FPR down a little to enable me to thread the new one on. Crisis averted~
    EDIT: Epoxy held long enough for me to get the airbox back in the bike then broke off again~
    All back together, reinstalled my D&D slip-on pipe. LOUD.
  3. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Try removing the idle speed screw.
  4. TNRabbit
    TNRabbit New Member
    Woodford, VA
    That's exactly what I did...it came to me in a moment of clarity~
  5. vranak
    vranak New Member
    Czech Republic
    Hi, did you remove the fuel tank before removing the air filter housing? And what about depressurizing the fuel system? It seems to be a must before changing the regulator.
  6. TNRabbit
    TNRabbit New Member
    Woodford, VA
    No, I just flipped the tank around on the seat area with a blanket under it. I didn't depressurize the system; I put a pair of vice grips on the hose to shut off the flow. However, it hadn't been started in several hours when I did that....
  7. vranak
    vranak New Member
    Czech Republic
    I did it the same way and it worked perfectly. The worst part was to loosen several bolts in the regulator's surroundings so that I could tighten the regulator securely to the railing without any damage. I managed to do it and today I've finally enjoyed after several months a perfect ride. All of the posts here at the VFRworld were really helpful. It's good to be a part of it.
