Can anyone explain this? 5th gen carb...
Discussion in 'General VFR Discussions' started by steven113, Jan 16, 2010.
  1. steven113
    steven113 New Member
    Pensacola FL
    I saw this posted on ebay and contacted the seller to let him know that his listing was incorrect before teh sale caused him or the buyer a problem. He swears that these carbs came off a 99 vfr800. I think I may have read somewhere that there are a few very early 98 model vfr800s that came carburated but I have been unable to find any information on them and this setup does not look like any of the earlier vfr carb setups but does look as if it may fit the vfr800 motor. Do any of you have any insight into this?
    98 99 00 01 Honda VFR 800 THROTTLE BODY CARB CARBURETOR : eBay Motors (item 180422660940 end time Jan-18-10 23:49:38 PST)
  2. Scott_Lilliott
    Scott_Lilliott New Member
    Sweden
    Massachusetts
    THose are not carbs, they are the fuel injector bodies and frame support. The seller obviously doesn't know how to spell 'fuel injector assembly'.
    I don't see the injectors, they may be on the other side. It would be really underhanded if they were removed before they were sold.
    Scott
  3. steven113
    Pensacola FL
    after looking closer it is the underside of the throttle body assembly without the fuel rails and injectors. for some reason it did not look the same to me. Is there any truth to some of the early model 98s being carbed or am I just mixing things up?
  4. NorcalBoy
    Scott nailed it. What is shown, in my best estimation, is a disassembled set of tb's. Without a complete top view, i'm pretty sure the fuel rails, injectors and injector wiring harness have been removed.The injector wiring harness is gone for sure, that is why he is showing that bottom view. The only thing that setup would be good for is a $79.99 ashtray or a paper weight. There were no carbs after 1997. Now scamper off and tell him what a douchebag he is for trying to sell that stuff.
  5. davyboy
    davyboy New Member
    dublin
    my august 98 800 is most defo fuel injected.
  6. rccaulfield
    rccaulfield New Member
    Sure i bought a givi rack for a 98 vfr 800 from a lad in england last month. Turns out it waqs a late registered vfr750! The fella hadnt a clue wat bike he was driving-i got stuck with them!
  7. hatzyian
    hatzyian New Member
    Larnaca Cyprus
    If the advert was incorrect, get on to ebay, and you should be able to get your money back.
  8. steven113
    Pensacola FL
    I did not buy these... I just saw them listed and thought the seller was making a mistake in his listing. Turns out it is what he was intending to dell off of the correct year bike, just not the complete assembly with rails and injectors.
