cam timing
Discussion in '1st & 2nd Generation 1983-1989' started by woodwizzard, Oct 27, 2007.
  1. woodwizzard
    woodwizzard New Member
    somerset uk
    Hi all, not sure if this has been covered on this site or not but when installing my cams on my vf1000 1984 I just couldn't get the timing set up correctly, after a bit or research it turns out that the clymer manual is wrong. 3 times I installed and stripped out the cams and just couldn't see what I was doing wrong:rolleyes: I also have a genuine honda book which I then looked at and it describes a different method of setting up the timing marks. Having now followed the honda manual all seems ok.
    I expect this is covered on here somwhere so I won't go into details, I confuse myself most of the time so god knows what I would do to you guys:biggrin:
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    This is one of the few areas where the Honda manual is incorrect. All four cams are set at the T1-3 mark.
