Bridgestone BT 21 tires
Discussion in '6th Generation 2002-2013' started by whitevfr, Oct 1, 2010.
  1. whitevfr
    whitevfr New Member
    Nashville
    After 2 sets of dunlop Qualifiers I wanted a tire that lasted longer. BT 21's had a great price and was supposed to last alot longer. Worst tires I have ever put on a bike, tires are totally shreded at 3800k miles, front is totally bald, rear center is gone. Corning grip was scary, I keep feeling the rear start to slide in spirited corning. Confidence killer. Ordered a set of Pilot Roads 2CT's , hopefully these will fair better. Just wanted to let anyone considering BT-21's know my experience on them. Qualifiers were awesome tires, cornered great, lots of grip, just don't last long.
  2. stewartj239
    stewartj239 Member
    Syracuse, NY
    This past winter, I put a new set of the Bridgestone Battlax BT-020 tires on my '07. I've got about 3000 miles on them with no signs of wear yet. I hope they hold up better than yours did. I hope to get the rest of this year and next year out of them.
  3. bitterpil
    bitterpil New Member
    Northern Virginia
    That is entirely wierd. They are a pretty hard compund actually dual compund. Yours is the first negative complaint i have read. Most people get 8k from a set and do not have slipage issues. I ride the much softer compound bt016s and I get 6k out of them that is with all sorts of riding. I ride HARD most of the time and commute others. Cant imagine what you did to get the longer lasting tire to wear so quick considering qualifiers have a rep for not lasting too long.
    Now the new bt023 is supposed to be better than the bt021. I have not tried it. The new qualifier 2 is supposed to last longer as well. Not to mention the Q2s should provide better everything than the qualifiers.
    I tear it up and i get over 5k a set no matter what i ride, mich pp2cts or bt016 both are softer yha. The bt021 dual compound.
    Also the tire you came from is a sport tire. The st tire bt021 and the new one you ordered are round profile. It is easier to get to tthe edge on a round profile tire. The mich pp2ct is a more triangular tire than the pr2ct. It shoukd be easier to get to the edge on the pr2ct than on the pp2ct or the qualifiers you came off of.
  4. whitevfr
    whitevfr New Member
    Nashville
    I ride hard, back road romping around but I do not do burnouts or anything like that. I consistently check tire pressure. The BT 21's just could not hold up. It is a pretty hard compound which for me translated into rear tire slippage in corners. Only thing I can think of is "riding hard" is a relative term. I'm just not sure. The qualifiers I used previously I got 3ish k out of the back and 5ish k out of the front, which seems to be what most people get out of them. Hoping the Pilot Road 2 ct's live up to the reviews and hype for me because they are expensive:frown:
