Brake Part Swap?
Discussion in '1st & 2nd Generation 1983-1989' started by 199q, Mar 25, 2009.
  1. 199q
    199q New Member
    Chico, CA
    Hey guys I have an 86 700 and I need to get some new rotors. I know that the CBR 600 F2 rotors work, but does the rear CBR F2 brake mount up and work as well? or maybe does anyone know what brake parts will swap with my bike? there is a ton of stuff for the F2 on ebay and much less for my VFR.
    Thanks!!
  2. risoto
    risoto New Member
    San Luis Obispo, California
    I have a good used set of stock vf rotors fronts and rear, I could let go cheap.
  3. 199q
    199q New Member
    Chico, CA
    Ill take em!! I sent you a PM to work out the details.
  4. 199q
    199q New Member
    Chico, CA
    they might not work though, I do have an 86....
  5. crustyrider
    crustyrider New Member
    North Country, New York
    do you have an 86 VFR or VF?
  6. 199q
    199q New Member
    Chico, CA
    I have a 1986 VFR 700 F
  7. risoto
    risoto New Member
    Anyone who knows for sure back me up but I think the 84 vf rotor bolt pattern fits the newer models. Not sure about the back.
  8. risoto
    risoto New Member
    vf 750 rotors
    The brake rotors appear to have the same bolt circle front and rear about 6 1/2" diameter. The rear rotor is larger than the fronts at about 11 1/2" diam.
    The rear is 6.32mm thick and minimum is 6mm. The fronts are both at 4.7mm thick and the minimum is 4mm. These rotors need a good cleaning and you could paint the centers to be neat.
  9. 199q
    199q New Member
    Chico, CA
    I will look tonight. sorry I have been slacking! thank you though I will measure and get back to you tonight.
