Brake line repair at the nipple possible?
Discussion in 'Mechanics Garage' started by tcmdoc, Oct 15, 2009.
  1. tcmdoc
    tcmdoc New Member
    Clearwater, Fl / Saint Simons Island, Ga
    During transit yesterday my front brakeline broke right at the connection under the reservoir by the right handle.
    Is there a way to cut and re-clamp this line or do I have to get a new one.
  2. TOE CUTTER
    Replace
    No you can't repair it and if you could you would not want to.
  3. tcmdoc
    tcmdoc New Member
    Kinda figured. Kinda sucks. Just dropped a bundle on the carb work and new tires yesterday. Probably better it happens now then when I am on the road.
  4. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Yes, much better now than later.
  5. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    All I saw was nipple in the heading and got my hopes up...I am very disappointed...such language should not be allowed unless talking about the real thing...
  6. crustyrider
    crustyrider New Member
    North Country, New York
    hee heee hee heee. he said nipple
  7. donald branscom
    donald branscom New Member
    Guerneville CA
    About the Ronald Reagan quote.
    He tried to stop Social Security. He had a rich Doctors wife - !@!@#%$#@
    everybody else right?
    Also about the brake line. YES you can remove it and take it to a hydraulic shop and they can fix it. The have the special tools to do it.
  8. SA1713
    SA1713 New Member
    What's the length? I may have one laying around.
  9. steven113
    steven113 New Member
    Pensacola FL
    Most hydrolic shops will not repair or make brake lines for liability reasons. I dont see anything wrong with the integrity of the repair if it is done by a hydrolic press specificaly for hydrolic lines but the fittings are not all that cheap and there will be a service fee also... IMHO Order a new line, both end fittings and the hose will be new if you go this route. Brakes are rather IMPORTANT!
  10. donald branscom
    Guerneville CA
    When I was in the military the hydraulic shop repaired and made hydraulic lines all the time. They would make anything you want. Just have to have the right tools. The swaging machine,fittings and skill. Shops fix hydraulic lines for heavy equipment that gets broken too.
  11. crustyrider
    key word here....MILITARY...I was in the military as well and we made all kinds of stuff...bottom line is military people can't sue the govt......thats why we have been used as guinnea pigs for "new and improved " items.. anyway..go get a new line then you don't have to worry about it ..
  12. TOE CUTTER
    Really?
    Not sure where you were going with the quote but, we repair and fab brake and hyd lines all day every day but not after it has had fluid in it. Do not know of a shop that will touch a brake line that has been in service.Having a front brake line fail while .......well enough said.
  13. squirrelman
    Why not spend for a steel-braided setup now?? Better braking is the result.
