Brake disc bolts
Discussion in '5th Generation 1998-2001' started by yellow99, Oct 13, 2014.
  1. yellow99
    yellow99 New Member
    Lincolnshire
    Just removed both front discs. The workshop manual says that the allen bolts must be replaced with new ones when re-fitting. Anyone know if this is absolutely necessary, and why this is the case?
    Ta
    Martin
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    I believe there is a previous thread on this subject.
  3. TOE CUTTER
  4. marriedman
    marriedman New Member
    Dayton, OH
    I have reused mine several times without issue. Make sure and do a very close inspection of the threads though. and use the proper locktite.
  5. RDMCD
    RDMCD New Member
    London Ontaorio
    Clean threads, apply new loctite, torque properly, and ride.
  6. yellow99
    yellow99 New Member
    Lincolnshire
    That's really helpful, thanks. At the end of the day I have no idea if those discs have been removed before I took them off and whether new bolts were used so for all I know they've been on and off a number of times. However, there is red thread lock on each bolt that came off in dry fragments, so maybe they've never been touched. I'll have a good look at them and if they're salvageable will probably re-use them with new thread lock (after cleaning the old stuff off). I've never replaced caliper bolts though and I've had them off and on with different bikes with no problems.
  7. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I've always reused the old ones. Just be very careful while tightening, it doesn't take too much overtorque to strip out the threads in the wheel.
  8. 34468 Randy
    I used mine over again when I painted the wheels. I believe the issue would be that the shear strength may be diminished a bit with re-use. But there is what, 8 bolts on each side? If one were to break, even two, I suggest you have enought in reserve to bring the bike to a safe stop. But next time I do my brake pads, I will be replacing the rotors too. After all, these have stupid high miles on them (original to the bike) so it is time to replace if just because. And I will put new bolts in at that time. Again if for no other reason, just because.
  9. flymyassoff
    flymyassoff New Member
    I've reused disc bolts as well. On my Blackbird. Works. I've also successfully reused gaskets and seals (clutch master and slave assemblies) as well that I wasn't supposed to reuse...
    Fly
    "Speed Is Life!"
