Bolts?
Discussion in '1st & 2nd Generation 1983-1989' started by Meremortal, Jul 9, 2023.
  1. Meremortal
    Meremortal New Member
    What grade bolts do you use on frame, fittings and fairings on a rebuild?
    what about stainless?
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Stainless won't rust, but can corrode/gall badly where it threads in, and not as strong as regular strength bolts.
    For important fasteners, I'd stick to steel. Or if you're really flush titanium. :)
    squirrelman likes this.
  3. bmart
    bmart Insider
    Charlotte, NC
    Isn't stainless...steel? Even in stainless, there are varying qualities available. I'd do some research.
  4. RogueRC24
    Bodywork: Aluminum or Stainless
    Frame: Stainless or OEM with anti-rust treatment
    Windscreen: Aluminum and Plastic
  5. Meremortal
    I thought about Titanium however I was concerned about galling and galvanic corrosion against the steel frame.
  6. Meremortal
    Thanks yes I was aware of different grades. I would be looking at 316 (marine) grade.
