Blown Turn Signal Fuse
Discussion in 'General VFR Discussions' started by grabcon, Feb 10, 2017.
  1. grabcon
    grabcon New Member
    Castle Rock, CO
    I am looking at picking up a 2006 VFR800 non-ABS. The guy says that the turn signal fuse keeps blowing and that this is a know issue on these bikes. He also says there is a fix on this forum. I have not heard of this issue and can't seem to find anything on it. I go to look at the bike on Saturday morning, having info before then would be great.
    Can anyone shead some light on this issue? Thanks.
  2. GigemVFR
    GigemVFR New Member
    TEXAS
  3. duccmann
    You may want to check the turn signal fluid
    I had to good luck
  4. grabcon
    grabcon New Member
    Castle Rock, CO
    Thanks much for the search insite
  5. grabcon
    grabcon New Member
    Castle Rock, CO
    Yep I have had that issue before but could not find the appropriate fluid locally. Had to get it from Europe.
  6. 34468 Randy
    200,000 km on my 2006 and I have never blown a signal light fuse. A few friends of mine here also had 6th gen VFRs and never had an issue. This guy is full of shit. There is no known issue I am aware of. There is something wrong and either your time to make the repair is reflected in the price, or he fixes it for you. I would go for the former as he is likely just to replace the fuse and then you are left with the issue.
  7. grabcon
    grabcon New Member
    Castle Rock, CO
    Randy that is kinda what I thought. But the price is right so I will see when and if I go. Thanks.
  8. GigemVFR
    GigemVFR New Member
    TEXAS
    Play dumb and tell him it concerns you and to knock some money off the price since you are unsure how to fix it. Use it to your advantage when negotiating.
