Bleeding brakes 6th gen
Discussion in '6th Generation 2002-2013' started by olivino, May 9, 2008.
  1. olivino
    olivino New Member
    New York
    Has anyone bled there own brakes on 6th Gen? I read that for linked brakes one needs a special (and expensive) vacuum tool and should therefore have a dealer do this. I mention this because I see an air bubble in the MC window hole - but the brakes feel fine.
  2. two4one
    two4one New Member
    Mohrsville, PA
    The bubble is relatively normal. I see it on a like of new bikes.
    As for bleeding, easy as pie. I use a MityVac. You can find these at most automotive stores. Not sure what you read concerning an "expensive" bleeding tool. Do the front then do the rear same as any bike so I've found. Others may disagree but that's my process and I'm sticking to it :)
    Mityvac
