Black Widow high rise link pipe & Scorpion can
Discussion in 'Gear & Accessories' started by scottbott, May 4, 2021.
  1. scottbott
    scottbott Member
    Grantham,Lincolnshire,UK
    IMG_1460.jpg IMG_1453.jpg IMG_1454.jpg already had the Scorpion can mounted at the original height and ordered a Black Widow high rise link pipe and hoped they would fit each other, the mounting bracket seemed nice and strong but when fitted the can could moved in and out a bit so ended up making a bracket myself and fitting it to the subframe also had to trim a bit of bodywork off to clear the mounting strap but it fits if very close to the rear mudguard so will keep an eye on it, also had the wheels powder coated in silver which makes a huge improvement to the bike imo, a couple of photo's, the mount ing bracket from Black Widow has a 'dogleg' in it photo's I have seen before are flat strap metal
  2. fink
    fink Member
    Sounds like typical black widow stuff ( formerly sandy bike spares).
  3. scottbott
    scottbott Member
    even though I got it fitted it was not as good a quality as the Scorpion for fit to the original pipework, I was a bit dubious when there was a tube of "Firegum" supplied with it, the "heat shield" has quite deep marks on it maybe from when it was curved into shape and I managed to polish most of the marks off , how does Delkovic quality compare I wonder?
  4. fink
    fink Member
    Much better quality.
