Bike ID.
Discussion in '6th Generation 2002-2013' started by Junyr, Apr 20, 2010.
  1. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    What's the easiest way to determine if a 6th gen is a California bike?
  2. Junyr
    Junyr New Member
    NVM after further research I think I've discovered that all the 6th gens were built to cali emissions.
  3. havcar
    havcar New Member
    Denver CO
    Yep, all of them is correct. There are ways around it and your bike will run better, but it's going to set you back roughly $1500.
  4. elwray
    elwray New Member
    Central NJ
    ...? more info?
  5. havcar
    havcar New Member
    Denver CO
    Delkevic (or motad) downpipes for a '98 or '99 5 gen...$250
    A good mid-pipe and chimney...$700-$800
    Eliminate the pair valve...$10
    02 eliminators to minimize the ECU's affects and maximize power commanders affects...$40
    PCIII with a custom Dyno to tie it all togather...$600
    You could probably go even further than that, but something tells me you know this Wray.
  6. elwray
    elwray New Member
    Central NJ
    Oh that's what you were referring to -- I thought you meant something about removing the emissions stuff to make a "49 state version" which would be $1500... I figured evap can and PAIR valves... then wasn't sure where the other $1490 was going ;)
