Bike electrics completely dead 2002 model
Discussion in 'Mechanics Garage' started by 5 speed, Jun 29, 2008.
  1. 5 speed
    5 speed New Member
    It seems someone else is experiencing the same thing here on an older model so I added to their post as well. Any ideas what this could be?????
    I rode all day yesterday. When i came home and up my street I wound it tight in first, then everything went dead. I pulled in the clutch and hit the starter and it fired right up.
    I got up this morning, went to get some breakfast. It started and rode normal. When I came out from breakfast, put the key in, the dash came on, the fuel pump started, then suddenly everything shut down. Clock on with key off, turn key on, nothing and clock goes off. Got towed home, hooked my battery to the charger and it immediately showed green. Its not the battery. I did find out from the original owner that the wiring harness recall was performed. He told me he has had zero issues with the bike. It has 17K on the odo. Guess I need to take it into Honda after I check the fuses. I suppose it could be a relay.
    Guess what I heard about electrical problems with this bike are proving to be true.
