Bent fork...
Discussion in '1st & 2nd Generation 1983-1989' started by Billiam500, Mar 30, 2009.
  1. Billiam500
    Billiam500 New Member
    So I removed the forks in order to change the fork seals, and noticed that one of them was bent slightly. The bend is at the top of the slider while at full compression, and when put against a straight edge, is about 1/4" off from the rest of it.
    My question: Is it essential that I replace it? The bike rides straight and I didn't even notice it until it was removed.
    Thanks!
  2. RVFR
    I would be Replacing it, way to much of an important piece not to be right. Not that you didn't notice it. it's all a matter of knowing, now that you do, it will bug you. you have half the job done, might as well make it right.
  3. ianjoub
    ianjoub New Member
    Homosassa, FL
    1/4" is more than I would try to straighten.... replace it.
  4. Billiam500
    How much should I expect to pay for a replacement?
  5. ianjoub
    ianjoub New Member
    Homosassa, FL
    what year/model?
  6. ianjoub
    ianjoub New Member
    Homosassa, FL
    and about $200 generally speaking
  7. midias
    midias New Member
    Rochester NY
    Look on ebay you may get lucky.
    On a side note if I were to lay a fork tube on a granite table what are the tolerances on how straight it should be.
  8. Billiam500
    '86 VF500f.
    $200 for a new(are they even still available?) or used?
  9. midias
    midias New Member
    Rochester NY
  10. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Billiam500:
    I think Traxxion Dynamics can straighten bent fork tubes.
    Google them and see, you may have to call them too.
    Somebody confirm!
    BZ
  11. ianjoub
    ianjoub New Member
    Homosassa, FL
    fork tubes can be straightened, but 1/4" is a pretty good bend. I would replace it. I am sure a new one is available from Honda, and yes, +/-$200 for a new one.
  12. ianjoub
    ianjoub New Member
    Homosassa, FL
    service limit on fork tube runout is .2 mm
  13. RVFR
