bent clip on - reason for concern?
Discussion in 'Mechanics Garage' started by bernside, Mar 17, 2010.
  1. bernside
    bernside New Member
    Eastern NC
    I noticed that my right hand gets closer to the tank then the left. Further inspection revealed that the right clip on is actually slightly bent.
    I figure trying to bend it back and stressing the metal again would probably be bad. Plus you cant tell going down the road, just turned to full stop.
    When I bought the bike the end of the brake lever was snapped off so I know it was dropped.
    No visible signs of cracks, etc...should I be looking to replace this or no?
    thanks,
    B
  2. TOE CUTTER
    I would replace it. It would drive me nuts......nuttier
  3. elwray
    elwray New Member
    Central NJ
    Could you just rotate it a touch forward so it's more or less equal to the left? The notch may prevent moving it very far, but might be just enough to make them even-er...
  4. bernside
    bernside New Member
    Eastern NC
    ggood thought but they are both already rotated all the way forward.
