Battery issues
Discussion in 'Introductions' started by HMR, Jan 23, 2011.
  1. HMR
    HMR New Member
    The battery on my 91 vfr is discharging while I'm riding, going dead after 30 minutes or so. Battery seems to hold a charge when trickle charged and the reg/rec has only about 2000 mi on it. the bike has 33K. Anyone have ideas? Seems like it might be the stator but I've never had a stator go bad.
  2. TOE CUTTER
    Have you inspected the wiring and connections at the R/R and the starter relay?
  3. tinkerinWstuff
    don't forget the three prong - stator to harness plug. Located on the right side under the middle fairing.
  4. squirrelman
    :welcome:
    First post a charging issue ?? Welcome to the club !!
