Battery issue?
Discussion in 'Mechanics Garage' started by linkken, Sep 20, 2021.
  1. linkken
    linkken Member
    Fortine, MT
    Okay, so now I just had a problem with my battery! It just died not even a mile from my house!!
    So again I just got a 1992 and I am trying to figure this thing out.
    It is cold here in Montana right now so I let it warm up a little bit (maybe 5 min.) and then I have to let it idle down my dirt road for a ways. Well I did not even get to the pavement and it totally died. My guess is that it will not charge the batt. unless you have some RPMs.
    So my question is at what RPM does it charge and how long should it run on the battery alone before you get in trouble?
  2. fink
    fink Member
    On a fully charged battery it should last a few hours.
    At idle it won’t be charging.
  3. Terry Smith
    I would be putting the battery on a charger, then firing the bike up, and measuring the voltage across the battery terminals with the engine running. You should see something in the range 13.5-14.5V; anything lower and the charging system may be suspect e.g. a dead regulator/rectifier or a burnt out alternator. If the volttage looks OK then the battery is probably toast.
  4. ridervfr
    Granite Blue 92? gota see some pictures - check voltage when your starting bike. How old is battery?
  5. linkken
    linkken Member
    Fortine, MT
    I charged up the battery, it takes a full charge. (13.5v)
    With the meter still on when I start it it will drop down a little, then when I give it some revs my meter starts freaking out!
    Numbers jumping all over the place!!
  6. linkken
    linkken Member
    Fortine, MT
    Okay I charged the batt. and rode it, it only lasted about an hour!
    It has some newer (not factory) wiring and what looks like a replacement rectifier/regulator?
    would it be just a bad alternator??
  7. tinkerinWstuff
    gotta check the connectors, ohm out the stator, then figure out which component is bad. Common VFR issue.
  8. linkken
    linkken Member
    Fortine, MT
    This thing is definitely not charging!
    I just put new higher wattage headlight bulbs in, would that have anything to do with it?
  9. linkken
    linkken Member
    Fortine, MT
    ohms out of the stator? Would that be checking impedance on the stator itself?
  10. squirrelman
    study the factory service manual to learn how to test the AC stator output.
    and reaD "the drill"
    ridervfr likes this.
  11. linkken
    linkken Member
    Fortine, MT
    Yeah, just like that with a Yoshi pipe!
    I'll get some photos soon, just still trying' to figure this thing out!!
  12. RllwJoe
    RllwJoe Member
  13. linkken
    linkken Member
    Fortine, MT
    Okay will do, thank you! what is "the drill"?
  14. squirrelman
    the drill is complete testing directions to sort out any charging problems. covers just about everything u might need to know.
  15. linkken
    linkken Member
    Fortine, MT
    where do I find "the drill"?
  16. linkken
    linkken Member
    Fortine, MT
    oh, I see. post #9 thank you!!!
  17. linkken
    linkken Member
    Fortine, MT
    Good stuff, thanx y'all!!!
  18. linkken
    linkken Member
    Fortine, MT
    So there is power coming from the stator to the r/r when I put the lead for my meter on the red wire out of the r/r it really @#%!s up my meter?
    what should it read at the red wire? something like over 14v right?
  19. linkken
    linkken Member
    Fortine, MT
    One yellow wire reads 25v AC, one is 20v and the other is 18v is this good?
  20. Skipper
    Skipper New Member
    Brisbane Australia
    When you say "I drop it down a bit and give it some revs and it starts feakin out. jumps all over the place"
    That sounds suspiciously like R/R to me. If the voltage test coming into the R/R from the Stator is consistant and correct across the three phases I would be buying a new Mosfet type regulator/rectifier and fitting it - worked for me, but then I never had a flat battery either, just blew a couple of headlamp bulbs.
    So - check the voltage output from the Stator first!
