Battery getting weak perhaps?
Discussion in 'Mechanics Garage' started by katat58, Mar 31, 2010.
  1. katat58
    katat58 New Member
    Hazen, AR
    Rode the bike to work today and it started fine this morning, first crank and varoom. Getting ready to leave after work and with a couple of cranks, varoom. I go maybe half a mile and gas it up, I then try to start it and it cranks 4 to 5 times then quits. It tried to fire off but didn't. I hit the starter again, it cranks a coupel of times, albeit slowly and fires right up. I noticed my odometer and clock were back to default. Is this an indication the battery is fixing to go tango uniform or is there something else lurking that I don't know about? The bike is an 06 and the battery is the original.:confused:
  2. TOE CUTTER
    Replace the battery and take a quick check of the chargeing system, but I would suspect nothing more than a new battery is needed.
