battery/charging diagnosis help
Discussion in 'Mechanics Garage' started by Bikermike, Dec 11, 2006.
  1. Bikermike
    Bikermike New Member
    What is the correct output of the R/R for a 1996 VFR 750?
    Mine is returning 13.5 v to my new on now fully charged battery.
    But i am still having battery problems.
    Thanks,
    Bikermike
  2. dskelton
    dskelton New Member
    Fitzwilliam, NH
    It's doing exactly the same thing? It will crank over the first time, but does have enough juice for a second try? Did this happen even right after the fully charged battery was installed? If the bike continues to run for long period after you bump start it with a dead battery the charging system is probably working OK (although I'll admit I have no experince with the R/R). What happens if run the bike for a while, shut it off, and try to start it right back up? If you have the same problem then, I'd suspect the starter.
