Bar end mirrors
Discussion in '1st & 2nd Generation 1983-1989' started by Lucas, Dec 28, 2008.
  1. Lucas
    Lucas New Member
    Has anyone put bar end mirrors on a VF? Love to see pics...
  2. k2them
    k2them New Member
    I plan to do this. It'll be a few weeks till they go on, but when I do I'll try and remember to post pics
  3. drewl
    drewl Insider
    Virginia Beach, Va
  4. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
    Hello
    When you talk about barend mirrors are you talking about mirrors witch are put straight on the plastic.If you mean that then I have done it and it looks nice.But I am still trying to set my pictures into this site and it is not working for me,I can not get them small enough in bytes.
    Best regards
    Gunnar
  5. jamey2466
    jamey2466 New Member
    yes i have it on my bike it looks great but i have a vfr 700f streetfighter and i made them my self look at my pic
  6. Tinman
    Tinman New Member
    New Mexico
    I have used two different sets of bar end mirrors on my vf750f. If you check my pics you'll see the napolean mirrors I had on before which I have since changed to the small round ones (like the crg bar ends). Bar end mirrors look the best in my opinion and really get rid of all the clutter but I also don't care much for all the extra junk on bikes (plastics, bags, etc). I'll post a pic soon of the bar ends I purchased on ebay for about $20 shipped.
  7. Knife
    Knife Member
    Downingtown, PA 19335
    I tried them on my '98, but it didn't work out. I couldn't find a pair short enough not to drag on the road in the corners.
  8. VFess
    VFess New Member
    Portland OR
    Picked these up in a bicycle shop, about $15.
  9. Lucas
    Lucas New Member
    They look great! What is visibility like? I have the stock units and they are terrible. The vertical range sucks, so if the road behind you isn't perfectly flat you loose a huge amount of range.
    Maybe I'm alone on this, but one of the most important things for a bike to be comfortable to ride for me, is a good set of mirrors...
  10. Lucas
    Lucas New Member
    Hey, tell me where did you get those indicators? They are about the only "mini" indicators of seen that suit the mid 80s styling of the VF. Most look seriously out of place...
  11. VFess
    VFess New Member
    Portland OR
    The bike was missing mirrors when I bought it from PO, so I can't compare them to stock. I will say the view is mediocre but better than nothing, a slightly larger diameter would help. If I hang onto this bike (considering selling), I'll doing something to improve the current mirrors.
    The bike had the turn signals already on it when I bought it, no brand markings on them, sorry.
  12. hondabill
    hondabill New Member
    LANCASTER OHIO
    I have picked up several sets of that style of lights at iron pony
  13. jamey2466
    y would i want to see where i have been.
  14. k2them
    k2them New Member
    Ha! VFess, we have similar bikes! same style and paint!
    I did all the paint myself, and yes I know I need a wind screen...
    Bar end mirrors work great! $16 for the pair. Ebay Special. It's a little hard to get them on if you have the stock bars. I had to grind off the ridge that would normally be used as a groove for safety wire on the hand-grips. I also had to mill away a bit of the throttle, but it hasn't affected the handling or performance any.
    @Lucas:
    The visibility on them is just fine. It's fairly narrow, but I have them adjusted so I can see cars coming from lanes adjacent from me (for commuting). I just turn my head for bigger looks. I'll re adjust them as my quick rear view needs change.
    I have similar turn signals as well. You can find them from any dealer that uses Parts Unlimited as it's distributor. They are generic ones and should run about $20 a pair. If you have a 750 you will need to make your own mounting brackets for the rears, I think. Two small pieces of spare aluminum work good. Should be able to be bought at a local hardware store for cheap if you don't have any. I took the "hand-rail" off of my bike so you should be able to use the existing holes from them if you are keeping them on. Also the wiring up front is real tight with the ones I used. If you take the Headlight off when you are hooking up the turn signals it'll be much easier.
  15. 243Win
    243Win New Member
  16. kenwood
    kenwood New Member
    San Diego, California
    Picked up a pair of Napoleon bar end mirrors off of Craig's List two days ago. Stopped by the store and picked up a new pair of grips (mine were tired anyway) that would look good with the ends trimmed off. With great anticipation, I cut off the old grips and pulled off the bar endcaps.
    Seems Honda has plugged the bar ends with a metal plug (perhaps for weight/balance?). I pulled out my drill motor and a 1/4 inch bit and, figuring to drill it out, started drilling. The stuff was tough! I drilled in about a half an inch w/o finding the end of it. I figured, What the Hell?, and pulled the grips off of my Nighthawk 750 to install them there and the bars were plugged on them too! Has anyone run into this? Do I have to replace my bars to install the mirrors?
    I'm totally pissed.
    _______________________________________________________
    How come there's never enough time to do it right...but always enough time to do it over?
  17. Tinman
    Tinman New Member
    New Mexico
    Christ it has been a while since I posted. Anyway, I had to drill my stock bars to get the mirrors to fit as they are solid (not hollow whatsoever). I also had to cut away at the actual mirror bar insert/expander so that it would fit in the narrow hole I made. I drilled in maybe 2-3 inches to get the mirrors to fit all the way in.
    I ran the modified napolean mirrors and drilled stock bars set up for a while with no problems until I finally picked up a set of clip ons that were hollow. I switched over to the round mirrors at that point.
    If you're resourceful you can get it to work. Best of luck.
  18. kenwood
    kenwood New Member
    I was afraid somebody was going to say that...Thanks a bunch for the info tho. I think it's worth it. Looks like it's time to test out my Craftsman drill motor! Will let you know how it goes.
    How did you clear out the bar ends? I figured on drilling and using a rat-tail file.
    Thanks again, this forum rocks!
  19. Tinman
    Tinman New Member
    New Mexico
    I just kept drilling until I reached the largest size bit then rinsed out the hole with a spray bottle I had handy. The hole was too small for the bar end so I had to shave the bar end insert down with a razor to get it small enough to fit but still big enough to fit tightly when tightened. I also had to grind the tightening nut to a circle so that it would fit in the hole. It is a tight enough fit that it still works fine.
    I later used the bar end mirrors on another project bike with normal sized hollow bars by just buying a small piece of rubber tubing found at ACE hardware store.
  20. kenwood
    kenwood New Member
    Thanks, Tinman.
