bad turn signal switchs on '96
Discussion in 'Mechanics Garage' started by amboyna, Oct 6, 2008.
  1. amboyna
    amboyna New Member
    El Paso, TX
    Faulty turn signal switches. ('96) I had to replace my turn signal switch last Oct. The replacement became very difficult to cancel especially from turning right. Last month I installed another switch and in 2 days and 800 miles it was doing the same thing.
    I asked my dealer in Las Cruces to contact Honda. No luck. Anybody have a phone number for a Honda rep?
    Apparently there's a little sealed spring behind the left-right-push button, and this is faulty in parts Honda is selling now. Maybe this is a job for some fine dremmel work, or maybe I should install a Yamaha switch or a generic double through switch. Or maybe I'll just buy a SV650.
    Any other ideas.
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    Try to buy a used one on eBay?
    I have nt had this issue on my bike. Do you park yours outside frequently?
  3. IrrerD
    IrrerD New Member
    Billings, MT
    I also had to replace my left-hand switch, but because of the high/low beam switch (toggle to high beam = no lights till jiggled correctly.) No problem with the right/left blinker switch. I think VT Viffer has the right question, though.
  4. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    No problem with mine ever and parked inside. Parts will have a one year warranty.
  5. amboyna
    amboyna New Member
    El Paso, TX
    Thanks guys. The third switch went bad on day 3, so it's not a matter of inside or outside storage. It's just a faulty part. I'm wondering if I can find someone to change the wiring to the switch so it works like my 86 BMW-the center position is OFF- no more push to cancel.
  6. squirrelman
    HEY!
    i've got a left hand switch set for your bike in excellent condition for $50 !!
  7. RVFR
    Exactly what I was thinking, that and you could get a hold of Service Honda for a new one.
  8. Rev
    Rev New Member
    Olympia,WA
    Haven't had that problem myself. I know there are a few people around who replace the LH controls with a late-model GSXR one. You have to do some splicing, but it's pretty straightforward.
  9. squirrelman
    only $50 will get you proper VFR switches, no splicing required.........
    pm me?
