back brake piston sticking on
Discussion in 'Mechanics Garage' started by status, Apr 19, 2010.
  1. status
    status New Member
    hi can any one offer any help on back brake piston sticking on cheers
  2. dizzy
    dizzy New Member
    MN
    Yes...usually it's caused by not changing fluid often enough. The caliper and piston(s) need to be cleaned and new rubber dust and ring seals installed. Make sure you clean the crystalized crap out of the 'landings' with a 90 degree pick. To disassemble most people used compressed air in the brake line fitting. I've found they come apart ALOT easier if you heat the caliper to around 200F first.
  3. betarace
    betarace New Member
    Middleburg, VA
