ATTN Eugene/Springfield VFR's! HELP NEEDED!
Discussion in 'USA - Pacific Northwest' started by estrada42, Aug 13, 2008.
  1. estrada42
    estrada42 New Member
    Help! I'm a Bay Area rider in Eugene and I'm in a bit of a pickle. I rode about 630 miles yesterday to get here and I noticed when I got here it was making an odd noise at low rev's. After a brief check I found my chain was so loose it was resting on the center stand.
    Here's my problem, when I bought this bike a couple of months ago, it didn't come with the factory tools. According to the FSM I need a special tool to adjust the chain tension. I don't have one at home, or up here.
    If there is ANYONE in the area who has the tool I need, and the maybe 5-10 minutes to walk me thru it, I would be beyond happy. If no one can help, I will have to find a local Honda dealer and buy one. (I plan to do that when I get home, but if I have to now, what can I do)
    I'm staying with a friend over here on E 18th by the campus, so please if you in the area, I can come to you!
    If you can help, please PM me a phone number. I'm stuck here until I can figure this out.
  2. R.W.
    R.W. New Member
    Cloverdale CA.
    On my VFR I can put it onto the center stand, loosen the bolt, and shake & spin the wheel and the chain will tighten or loosen with out the spanner wrench, if that doesn't work I'd try to sweet talk the service manager and temporally borrow the spanner wrench for 5 minutes...
  3. estrada42
    I'll be swinging by the Honda dealer in Eugene in the morning, but I would feel better if I didn't have to ride over there with a sloppy chain.
  4. estrada42
    All I managed to do is loosen it even more. I'll need the fancy tool.
  5. estrada42
    Okay, I'm officially counting on the kindness of strangers. None of the local dealers or shops have one of the tools for sale, and none of them are willing to let me borrow the tool for 15 minutes and do it here at the house.
  6. R.W.
    R.W. New Member
    Cloverdale CA.
  7. hondawolf
    hondawolf New Member
    Livermore, Ca
    Another thing you could do is use a punch or screw driver and tap with a hammer on the teeth where the spanner wrench would grab to rotate. Once you loosen the pinch bolt (19mm socket I think) about 3-4 turns or use a cresent wrench. It should adjust quite easily. Then retighten the pinch bolt to 54 ft lbs. if possible or just get tight by hand. When you loosen it, you can get a feel for how tight it was..... This is my suggestion, and only requires basic tools.
  8. whitesmokeyzf
    whitesmokeyzf New Member
    Albany Oregon
    And I have the tool! I could cruiz your way Friday night after work. I get off at 5 and could be ther around 6:00-6:30 Let me know.
  9. R.W.
    R.W. New Member
    Cloverdale CA.
    +1 on the Macgyver method...
  10. estrada42
    I had to punch/hammer it. Took me a while to dig a hammer up, but problems solved until I get back to the Bay.
    Thanks for everyone's help!
