Are you?
Discussion in 'Anything Goes' started by RVFR, Mar 13, 2008.
Key or Kill? How do you turn your bike off?
  1. Turn the Key
    66.9%
  2. Use the Kill Switch
    36.1%
  3. Leave it in Gear
    25.6%
  4. Put it in Neutral
    37.6%
Multiple votes are allowed.
  1. RVFR
    One of those that turn your bike off with the key, or the kill switch and once parked, do you leave it in gear or neutral?
    Key, neutral on centerstand, in gear with side stand
  3. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    Key on side stand in neutral...if you accidentally leave the key on while the kill switch is deactivated, all the electronics will drain your battery. I think the key is just safer.
  4. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    I use the key when leaving the bike on level ground whether I use the side or center stand. If parking on a hill and leaving the bike in gear, I just put the sidestand down, which kills the engine.
  5. reg71
    Sikeston, MO
    key, always. I forget about that other thingy...
  6. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Key, neutral.
  7. VFRShorty
    VFRShorty New Member
    NW Oregon
    key, in gear, mainly just old habit because the kill switch on my quad never worked!
  8. winaje
    winaje New Member
    Melbourne, Australia
    Kill switch, neutral.
    Reason for kill switch instead of key? Have always used kill switch. When I was getting my learners permit, the trainer said that it's a good idea to get used to using the kill switch so that it's automatic, in case something goes wrong and you need to shut the bike down really fast. Reflex action with the kill switch. I'm sure I'll get flamed, haha... :flame::flame::flame::flame::flame:
  9. elf800
    elf800 Banned
    dallas
    kill switch key lock steering side stand in first so it will not roll then look at it for few seconds and wished my ride was starting and not ending.
  10. douglasthecook
    douglasthecook New Member
    Tucson, AZ
    Clutch held in, bike into 1st Gear, side stand down, Key to off, clutch let out, dis-mount. I always keep my bike in 1st gear when I'm shutting her down, I know there's nothing wrong with nuetral while off, but I'm afraid that somehow she could roll, and hurt herself, so to mitigate that I keep her in 1st.
  11. desertman62
    desertman62 New Member
    Phoenix, AZ
    I use the key only. Parked: in neutral, mostly on the side stand with steering locked. Not too many hills / inclines to worry about in the Phoenix/Metro area.
  12. VT Viffer
    VT Viffer New Member
    South Carolina
    Key off, neutral. I almost ALWAYS put my bike on the centerstand, so being in gear is pointless...:rolleyes:
    If I choose to use the sidestand, I'll kill the engine by putting it down while in gear. But I'll only use the sidestand on level ground.
    Luckily, here at work, there is a 45' x 2' x 1/4" plate of steel on the ground and a bunch of curbing for a motorcycle specific parking area. I always use my sidestand at work becuase everyone else does... It would look silly if it was the only bike on it's centerstand...
  13. derstuka
    San Diego, CA
    I disconnect the battery...it hurts, but it is the only way I can be sure....
  14. powderrecon
    powderrecon New Member
    Seattle
    Key in neutral unless on a hill.
  15. MrJoelieC
    MrJoelieC New Member
    Milford NH
    I had the same instruction....
    I have to admit though I have done the "Leave key on" for just a littlebit too long once..... :frown:
    I tend to leave it in gear though... I've always driven standard cars and thus I have always left vehicles in gear as a habit....
  16. RVFR
    LOL I only use the kill switch when riding in groups at stop lights on other folks bike :evil:
  17. Taz
    Taz New Member
    from SoCal, now in Utah
    your right,
    Properly & Safely is 1. kill switch, 2. neutral, then key switch.
    Reason is you should work the controls closest to your hands, that way if something goes wrong, you can react faster :wink:
  18. drewl
    drewl Insider
    Virginia Beach, Va
    The manual for the 5th gen says use the key. That's what I do.
  19. SilverSurferRWB
    SilverSurferRWB Member
    Bay Area, CA
    Ditto!!!!!
  20. Action
    Action New Member
    Albuquerque
    That's exactly how I got used to using the kill switch :flame: Nothing like being a noob, nervous as hell, in traffic, and having your buddy hit your kill switch and ride off.
    Back on topic - I use the kill switch and leave it in gear.
    Action
