are tires suppose to be smooth?
Discussion in 'Mechanics Garage' started by jeange, Apr 20, 2011.
  1. jeange
    jeange New Member
    I have a 2005 VFR800A and I am quite new to biking and I was wondering if the rear tire is suppose to be smooth when you glide your hand over it?
    I noticed on my rear tire that I feel the grooves in the thread when passing my hand over the tire, it's not a smooth surface like a new tire would have. I have a metzeler roadtec z6 rear tire.
    Also I ride with a passanger alot if that changes anything and the tire pressure is 42 in the rear tire and I adjuted the preload on the rear spring to almost max.
  2. bitterpil
    bitterpil New Member
    Northern Virginia
    How old is the tire? Have you been riing on it?
  3. jeange
    jeange New Member
    well i bought the bike a month ago and the previous owner told me that he changed it at the beginning of the past season. I have probably put 300miles on the bike since I got it.
    also what is the typical average life of a motorcycle tire, how many miles?
  4. bitterpil
    Northern Virginia
    Old tires will be smooth and shiny. You get about 5-8k maybe a bit more depending on tire and how you ride.
  5. jeange
    jeange New Member
    so my tires aren't in normal condition?
  6. reg71
    Sikeston, MO
    This is bad:
    or this: [​IMG]
    this is ok: [​IMG]
    other than that, it's damn hard to tell from a few typed lines. If we could see them, we'd have an idea but to decide whether your tire is safe from reading the description and not even looking at a picture is very difficult.
  7. jeange
    jeange New Member
    ok I will try to post some pics although I guess in the picture it will probably look ok. It's not as bad as the pictures you showed me it's only when you glide your hand over the tire that you feel it.
  8. bitterpil
    Northern Virginia
    I dint say that. Tires wear but they also age. If your tires are old (dried out / begining dry rot and hard) they will be shiny and smooth like glass. On dry pavement not riding agressivly, ou will probably not notice. In the rain tho. If that is the case and since you bought reecently, you can / should at least look at new rubber.
    Tires should offer resistnace to your hand rubbing over it a kind of tackyness.
    More friction tahn tacky. Hard to do this over the interwebs.
  9. bitterpil
    Northern Virginia
    Hahahaha, yeah, cords showing is a lock. New rubber.
    Those things still hold air?
  10. jeange
    jeange New Member
    ok it's kinda hard to tell cause there is sand over the tire I would have to clean it to see if the rubber is tacky. I will try to get some pics up though
  11. tinkerinWstuff
  12. jeange
    jeange New Member
    ya the more I look into it, it does look like cupping. Do tire have to be replaced as soon as they show signs of cupping?
  13. Keager
    Keager Member
    I would. It can have very bad effects on running the twisties, and head shakes that can cause a crash.
  14. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    I think we need to see the pictures to get a better idea what you are describing.
    Uneven tire wear can be caused by a number if factors, including age, use, suspension health, load and what surface you typically ride on. I find that the front tire is far more critical and tends to cause adverse handling characteristics when it is in poor shape, incorrectly inflated, doesn't match the rear in profile or just simply doesn't suit the bike or the riding style.
    There is a crap load of stuff going on and the tires are quite litterally where the rubber meets the road. They should be the same make, model and series of tire and their condition should also align.
    This is a nicely scrubbed in rear with even wear.
    This is what you do with rear tires that don't deserve to live!
  15. havcar
    havcar New Member
    Denver CO
    Why anyone would replace the OEM z6's with another set of z6's is incomprehensible; leads me to believe that they are the original tires. Check the last four digits of the DOT number (or it's Canadian equivalent) on your tires right sidewall. The first two represent a week of the year, while the last two represent the year itself. If your tires are more than 4 years old then you should replace them. Regardless of age, if they're cupped, you should replace them (with something other than a z6). Also, you may want to take that rear preload down a click or two from maximum, unless the two of you are on the husky side. Then add (stiffen) a scosh of rebound from there.
    Tire Tech Information - Determining the Age of a Tire
  16. tinkerinWstuff
    no - not necessarily. Some cupping or scallop is normal.
