Anyone raise there stock bar the 1/8" that it seems you can do?
Discussion in '7th Generation 2010-Present' started by kurtfriedrich, Aug 9, 2014.
  1. kurtfriedrich
    kurtfriedrich New Member
    Eastside of Seattle
    It seems if you just loosen the pinch bolts on the stock bars, that they can slide up a bit until they hit the circlips. I know its only a little, but this change would be free?
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Yes. Did mine this way. It's good for me....never had any desire to move to any of the riser clipons. Although I've ridden bikes that ahve them--way too upright for my taste.
  3. OOTV
    OOTV Member
    I did that on my '09, as I'm using Heli-bars and the rearward offset puts the master cylinders right above the fork preload adjusters and they would not work any other way but raised on the fork tube. As long as you have the bolt torqued to the correct setting, I don't think it is a big deal. I've had mine this way for a couple of years now.
