any ignition guru's advice is welcome
Discussion in '1st & 2nd Generation 1983-1989' started by 904kevinw, Aug 26, 2010.
  1. 904kevinw
    904kevinw New Member
    Green Cove Springs, FL
    First, let me introduce myself as a newcomer here. I've gotten lots of good help from this site already just browsing through the different posts. Now I need help with my 85 VF500F.
    No spark is the issue. According to the Clymer's manual, the ignition coils are no good because they show infinite resistance between the secondary post and ground. I thought it was questionable that BOTH coils would go bad at the same time, so I checked at a local boneyard today, and put the ohm meter to about a dozen other coils of the same type off of various VF's. They all read the same. So, are they all bad?, or is the manual wrong? Not that I really care who's right and who's wrong, I just need to find out why I don't have any spark! Does anyone know what the accurate way of measuring these coils is, and what the values should be?
  2. TOE CUTTER
    Slim to no odd's both took a crap, I would check the pick up coil next.
  3. blitzas
    blitzas New Member
    Primary (Between spade connectors of ignition coil) resistance 2.8 Ohms
    Secondary (between ignition coils pins where HT cables attach) resistance 12.5 KOhms ~ 15.5 KOhms
    There is no ground in these measurements.
  4. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Yep, I would reconsider my tesing techniques or my ohmeter if I were you.
