Another 5th gen Stebel Nautilus horn split mount
Discussion in '5th Generation 1998-2001' started by duB, Feb 14, 2012.
  1. duB
    duB New Member
    Montreal, Canada
    Compressor and relay mounted in the tail on the right hand side
    Horn attached on a coil on the left side
  2. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Nicely done, mine is kinda jerry rigged up where your have your horn assembly. I need to split mount it at some point when I have access to a garage. I'd like to get the horns into the radiator opening in the front... not that it isn't loud enough as is.
  3. duB
    duB New Member
    Montreal, Canada
    I wanted it concealed and keep the stock one. The high beam signal triggers a relay that switches between the stock and Stebel, as I did on my 1st gen. I am riding on high beam all the time during the days so in case of emergency, the Stebel blasts. For a little polite beep, I just have to turn off high beam and beep. And at night I don't wake up the kids.
