another 5th gen freshen up modernization
Discussion in '5th Generation 1998-2001' started by rocketscientist, Jan 3, 2013.
  1. rocketscientist
    rocketscientist New Member
    australia
    i've posted a few threads for this project up already but i'vefinally started on my project sorry no pics yet.
    the progress over time i've owned it.
    1. first mod lighter chain and sprockets.
    2. lighter clutch. full barnett Kevlar kit.
    3. new fairings. ebay specials.
    4. fixed the reg rectifier issue. twice.
    5. fixed a dead ecm on it.
    last couple of weeks,
    new led taillight assembly
    new led headlights
    new led indicators
    new led every bulb in the dashboard
    total minus about 100w of electrical demand.
    got a couple of micro controller boards for building a new ecm.
    looking to include higher rpm limit, cylinder deactivation, wet/dry maps, etc
    programming is progressing slowly but still progressing.
    also looking at doing an adaptive suspension controller as well.
  2. Scubalong
    Now I know why your user name is......:rolleyes:
    Awesome.......job
    Cannot wait to see the actual bike.
  3. revguy
    revguy New Member
    North Bay Ontario
    thats awsome !!
  4. DaHose
    DaHose New Member
    Napa, CA.
    Are you dead set on making your own ECM? If not, you can get a microsquirt and do all custom programming for it. The hardware is already built and really nice to work with.
    MicroSquirt Engine Management System DIYAutoTune.com
    Adaptive suspension controller? Now that would be TRICK!!!!
    Jose
  5. rocketscientist
    australia
    Thanks but I am not a fan of the microsquirt/megasquirt range.
    Also using the same board/s for suspension controller, etc Making life easier for myself, or at least trying to, by using the same board.
  6. rocketscientist
    australia
    Forgot to mention in the original post also did rear wheel bearings and steering head about 6-12 months back. new fork tubes about then too.
    I'll also be doing an overhaul of the brake system. Maybe some braided lines. new rotors, brake pistons, etc are sitting in the shed waiting for me
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    how are you going to accomplish the cylinder deactivation?
  8. rocketscientist
    australia
    turn off fuel and spark to a cylinder or 2 for a few rpm. at light loads. if it doesn't produce desired results then. bastardized vtec with a dual lobe cam perhaps.
  9. rocketscientist
    australia
    New springs on the way, and some braided brake lines too. Looks like the adaptive suspension may be first cab off the rank.
  10. smack doogle
    smack doogle New Member
    Saint Leonard, Maryland, United States
    Wow! That's ridiculous. Shouldn't you be using that brain of yours to cure cancer or something? Geez!
    Seriously though, that sounds like a lot of work. Good luck. Looking forward to seeing the results.
  11. tinkerinWstuff
    Very unique. Quite interested to hear how things progress.
  12. rocketscientist
    australia
    Springs have arrived.
    fronts are installed, haven't change fork oil weight yet.
    The difference is night and day compared to stock but they aren't dialled in yet.
    pics of the hyperpro vs stock below,
    hyperpro is the one on the bottom.
    hyperpro is the one on top.
    Haven't fitted the rear spring yet.
    controller board is here. Just need to get some magnetic particles now.
  13. taylor65
    taylor65 New Member
    florence, al.
    How much were the hyperpro springs? Very interesting with the adaptive suspension. I wouldnt even have a clue as to where to start.
  14. Scubalong
    Great one Doogle :thumb:
    LMAO
  15. Scubalong
    I have fit it the Hyper Pro on my GS
    If I have to do it again I would go wwith Ohlin.
    BTW Nice stuff you got........Isn't it summer in Ausie right now? You should be riding in stead. :pound:
  16. rocketscientist
    australia
    lol. yeah would be if it'd stop raining and flooding every 5 minutes
  17. rocketscientist
    australia
    about half the price the Aussie distributors want for them online.
  18. rocketscientist
    australia
    I'm using the olimex stm-32a controller board for those following the project.
    any one have ideas for a cheap rig for testing fluid viscosities and effective spring rates?
    Still waiting on bolts for the new front brake rotors.
  19. rocketscientist
    australia
    rear spring on a 6th gen shock now installed. thurn 110 triangle at the same time. static rider sag is now equal front to rear. about 10mm so a bit in the firm side.
  20. rocketscientist
    australia
    Had the bike out for a ride today. It finally stopped raining!!!!!
    Suspension upgrade was definitely worth the $. Holds a line in corners well, very settled in the corners, uses it's tyres about right. Will be interesting to see how much better it can be made.
    Still working on a bare metal programming style for the microcontrollers. On a steep learning curve though.
