Analog Voltmeter 4th Gen
Discussion in 'Mechanics Garage' started by russ189, Apr 4, 2009.
  1. russ189
    russ189 New Member
    San Ramon, CA
    Anyone have an analog voltmeter mounted on their 3rd or 4th Gen? I'd like to see some pictures of some mounted to get an idea of a good place. So far, I haven't come up with anything except going with a digital meter.
    One of the Honda outboard volt meters would match well if I can find a place to put one!
    Analog Meter 1
    Honda Marine Meter
  2. russ189
    russ189 New Member
    San Ramon, CA
    There's got to be a 90-97 VFR out there somewhere with an analog voltmeter!
  3. Knife
    Knife Member
    Downingtown, PA 19335
    I've got a 1-1/2" diameter analog voltmeter mounted on my 5th Gen. Will a pic of that help?
  4. Slothrop
    Slothrop New Member
    northern lower Michigan
    I'd like to see it.
  5. Knife
    Knife Member
  6. safetypro10
    safetypro10 New Member
    Dallas, TX
    3rd gen analog voltmeter
    You asked. Marine analog in the Honda designed spot.
    Larry
  7. russ189
    russ189 New Member
    San Ramon, CA
    That's right, I forgot the 3rd Gen had the spot molded in the fairing. It looks like my only option for an analog meter is to cut a hole in the fairing.
  8. Yakima9
    Yakima9 New Member
    Wausau, WI
    Have you thought about something like this:
    BackOFF Voltage Monitor
    I have this installed on my 4th gen. I went under the front dash panel and took out the light for the side stand. I replaced it with this LED. It is bright enough that you can see the different colors through the amber lens. I wasn't real fond of drilling holes in the fairing or dash panel. The function of the side stand down kill switch still works, just don't have a light for it. I think you could come up with something that would be much cleaner looking than an analog gauge imo....
  9. russ189
    russ189 New Member
    San Ramon, CA
    Yakima9--
    Thanks for the suggestion. I considered an LED meter similar to what you have but prefer numerical readouts. Since I don't want to cut a hole in the fairing, it looks like I'll end up w/ a digital panel meter.
