alternator cover removal
Discussion in 'Mechanics Garage' started by cornhoolio, Sep 24, 2011.
  1. cornhoolio
    cornhoolio New Member
    I am doing a valve adjustment on my 85 vf500f, but cant get the alternator cover off. I dont want to smack it so hard as to crack it or scar the surface. Does anyone have suggestions? Are the mating edges smooth so that I could jam a putty knife through the old gasket? ~John
  2. lnb001
    lnb001 New Member
    Virginia
    You might try some penetrating lubricant (PB blaster) and tapping along the edges with a rubber mallet. I don't think the Alt. cover has locating dowels like the clutch cover does but it may be different for a 500.
  3. TOE CUTTER
    +1 with the love of a rubber mallet.
  4. Cogswell
    Cogswell New Member
    The aluminum is soft and the putty knife would stand a decent chance of gouging the case or cover mating surface which could end up being difficult to prevent leaking. Once off, a liquid or spray gasket remover rather than scraping the surfaces will ensure a leak free assembly.
  5. squirrelman
    Pop the tranny in 4th gear, up on the centerstand, and you can easily turn the engine by bumping the rear wheel around by hand. No need to remove cover.
