Alt./reg. wiring???
Discussion in 'Mechanics Garage' started by turbota2, Aug 15, 2012.
  1. turbota2
    turbota2 New Member
    Bastrop Texas
    Hi, I had an 86 and an 87 vfr 700s given to me a while back. I have the 86 running and rideable. I am replacing the regulator, the previous owner cut off the 3-wire connector between the alt. and reg. and twisted the wires together. I purchased the 3-wire connector. I purchased an aftermarket regulator for it. all the wires are yellow, does it matter in what order I put the wires into the new connector? Just got it running, don't want to burn it up!
    Wayne
  2. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Does not matter how they are connected. That being said, I would not install the stock conector....I would solder the stator wires to the RR wires direct and put some heat shrink tubing on them, etc. That will eliminate a failure point. I did that on my 2000 with zero issues.
  3. turbota2
    turbota2 New Member
    Bastrop Texas
    thank you very much. I didn't think it mattered but I wanted to be sure. The 86 vfr is yellow (good color). I have replaced some of the parts with parts from the 87 (love having a parts vehicle). Very close to getting it on the road, ready to check it out.
    Wayne
  4. CRFan1
    CRFan1 New Member
    Northwest Indiana
    No problem and good luck! Post up some pics too :smile:
  5. TOE CUTTER
    :worthless:
