Air Guide removal when lubing chain.
Discussion in 'Mechanics Garage' started by dougk35, Feb 20, 2012.
  1. dougk35
    dougk35 New Member
    Vegas Baby
    Does anyone remove what I believe is the "Air Guide" from the swing arm to make lubing the chain easier? 2007 800 RWB.
    See Vid.
    [video=youtube;e4ZTOSm8vhM]http://www.youtube.com/watch?v=e4ZTOSm8vhM[/video]
  2. stoshmonster
    stoshmonster New Member
    I suppose you could if you wanted to Doug.
    I never do,never found it to be in the way.
    I do remove mine every now and again to clean the chain gak off it though.
  3. NorcalBoy
    what.jpg ..........
  4. reg71
    Sikeston, MO
    wow, now that's an interesting way to ask a question! I never take it off myself unless I'm doing major chain work. Hell, I'm doing good if I even remember to lube the chain so...
  5. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    lube the chain? what's that mean?
  6. DaHose
    DaHose New Member
    Napa, CA.
    My ride came with a LoobMan auto-lube setup and I didn't even know there is supposed to be an "air guide" on there. In other words, I don't have one on my bike.
    Jose
  7. dogman
    dogman New Member
    Adelaide Australia
    Took mine off years ago, never missed it.
  8. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    What it is is a shark guard. Keeps fingers and toes from getting eaten by the chain and rear sprocket should you and your bike ever take a tumble. There are aftermarket ones out there that look much nicer.
  9. reg71
    Sikeston, MO
    Ahhh...that makes sense... I never thought much about it, but I can see how that would help. Getting your toes and or fingers pulled through something spinning like that must hurt pretty bad.
    Wonder if anyone around here can confirm or deny.
  10. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Google it... but have a strong stomach if you do
  11. KC-10 FE
    KC-10 FE New Member
    Didn't someone post a link about a pinhead that took off the tips of all his fingers while lubing his chain?
    KC-10 FE out...
    :plane: :usa2:
  12. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    It should be called an "airhead guard" for all the dipshits that think they can stall the bike with their digits, present members with superchargers not included..................
    Oops, suppose I should answer the OP's query, nope, only remove mine when I'm replacing the chain or doing other major work and it needs a good scraping to remove the built up crapola.
