ABS Option?
Discussion in 'General VFR Discussions' started by EdKnow2106, Jun 8, 2010.
  1. EdKnow2106
    EdKnow2106 New Member
    I need help. How can you tell if a 2002 VFR is equipped with ABS (other than the owner is telling you it is)?
  2. digitallyhip
    digitallyhip New Member
    Bowen Island, BC
    Two easiest ways are:
    1. toothed ring on the right side of the front wheel (around the axle); and
    2. remote preload adjuster for rear shock, mounted on the right rear footpeg support strut
  3. EdKnow2106
    Thanks, good info!
