98 VFR800 with Problems!!! Please help??
Discussion in 'Mechanics Garage' started by BigD46, Dec 19, 2011.
  1. BigD46
    BigD46 New Member
    Alabama
    First off, I have been searching for 2 hrs for anyone with the same problems, but everyone is having different "symptoms" Close but not the same.
    I have owned this bike for 5yrs and put 26,000 miles on it.
    Now for the problems....
    FI light comes on after 5 mins of riding (always has)
    Will not throttle... If I throttle really fast the engine will die, and anything over 3/4 throttle it actually feels like it is losing power!! (120mph top speed when this happens and takes forever to vet there) sometimes it runs with no problems. (1 out of 25 times)
    Also, when at idle the headlight is brighter than when throttling .
    The bike is a 98 vfr800 with power commander, and Yoshimura exhaust.
    Any help would be greatly appreciated
  2. nmlongrider
    nmlongrider New Member
    Las Cruces, NM
    Check and clean connector at TP sensor. Possible injector circuit fault. I'd also replace the fuel filter as a clogged one will increase current (voltage) causing a FI light and damaging the voltage reg.
  3. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Unless nmlongirider is right on, you need to pull the code that's throwing the FI light. Do you know how to, or do you have a manual.
  4. BigD46
    BigD46 New Member
    Alabama
    I do not have the manual, and do not know how to pull the codes. This is very aggravating... I put new plugs, and battery thinking that would fix it but NO! If I can find the TP sensor I will check and clean connection.
  5. Pliskin
    Pliskin New Member
    Sorry man. I didn't see your post until just now. I'm not at home to take any pictures, but try this to pull the code.
    Take your seat off. On the left side, tied into the wiring harness, there should be a loose hanging, female plug (no jokes about a loose hanging female). Its formally called the Service Check Connector.
    First question though - once your FI light comes on, what happens when you keep the bike running and put your side stand down? Technically, it should blink giving you a code. But if it doesn't you can go about it as follows.
    (Keep in mind that one long blink of about 1.3 seconds is equivalent to 10 short blinks. So if you get one long blink followed by 7 short, your total is 17 blinks).
    1, Have your ignition off.
    2. Short the Service Check Connector using a jumper wire (paperclip works just fine too).
    3. Turn your ignition on - you don't need to start the bike, but make sure your engine kill switch is in the "run" position.
    4. You should get "X" amount of blinks at this point.
    5. If the FI light stays illuminated, then the ECM has no data memory of what went/is wrong.
    Once you do this - and hopefully find out how many blinks - then post it back up here and we'll figure out what the problem is.
    By the way, the TP sensor would send off a code of 8 blinks. I know its located on the right side of the bike, right under the "corner" of the gas tank, but to be honest, I don't know if you have to take the tank off to get to it. I don't THINK you do, but not sure.
    One other thing: Did you try running the bike without the power commander? I may be one of the few, but I actually had a PC call it quits on me and that led to some problems.
  6. BigD46
    BigD46 New Member
    Alabama
    Ok, I tried the paperclip, and nothing happened(no light at all)
    After running for about 3-5mins the FI light came on so I tried the kickstand thing and got 8 blinks
    Not sure if it repeats itself but following the 8 flashes it is on steady for a second and 8 more an so on.
    I am hunting the TPS now.
    Btw while I was riding it just now it was as if it just lost a CYL (or 2)
  7. Pliskin
    Pliskin New Member
    Well the 8 blinks is definitely the TP. But if its 18 blinks (one long followed by 8 short) that's apparently for a cam pulse generator, but then you're bike probably wouldn't even start.
    The "symptoms" for the TP are "Poor engine response when operating the throttle quickly". Sounds like that might be the culprit. Perhaps nmlongrider is prophetic. See if you can find it, check it out, clean it up, check voltage.
    If you want to PM me your e-mail, I'll scan in the pages checking for codes and what to do for checking the TP sensor.
  8. BigD46
    BigD46 New Member
    Alabama
    Will Do! Thank you
  9. Pliskin
    Pliskin New Member
    Got your PM and sent you about 8 pages from the manual. Hopefully it goes through.
  10. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    It would be logical to remove the power commander before attempting to troubleshoot this.
    Rollin
  11. rc24rc51
    rc24rc51 New Member
    Liberty SC
    What Rollin said!
