so im rebuilding this bike, in the parts bin is the oil cooler and its hoses. Where does it bolt to, and what size bolt/nut does it need? The Haynes manual isn't any help here unfortunately Also, how does everyone get the rear tire off without a stand? Can it be done with the bike just on the center stand or is there another trick?
Parts diagram is often helpful for bolt info and mounting/assembly info: https://www.partzilla.com/catalog/honda/motorcycle/1995/vfr750f-a-vfr/frame Factory Service manual is available online in PDF format: https://www.manualslib.com/products/Honda-Vfr750f-1995-1865948.html
