94 order of ignition switch wires - soldering
Discussion in 'Mechanics Garage' started by tcmdoc, Oct 10, 2009.
  1. tcmdoc
    tcmdoc New Member
    Clearwater, Fl / Saint Simons Island, Ga
    My project bikes wires were pulled off their soldered mounts under the triptree.
    I plan on pulling the tree and resoldering but need the order of wires R R R/B
    What is the order they are supposed to be in? (Left Top Right)
  2. tcmdoc
    tcmdoc New Member
    bump....bump....bump
  3. squirrelman
    STUDY the wiring diagram in the service manual; it should answer your question.
  4. RVFR
    I looked over the shop manual, with out you being able to be here to see what it is all about, no telling. yes get your hands on a shop manual. you will be able to figure it out. I'd photo it for you, but there's to many little lines to be able to make sense of it all.
  5. tcmdoc
    tcmdoc New Member
    I must be looking too quickly at it.
    Today I will pull the switch, look at the manual...and multi-meter in hand... check then solder the wires.
    It might be less confusing after the part is pulled. I was going to do it while on the bike but I might just as well detail the whole thing/paint it while its out.
  6. tcmdoc
    tcmdoc New Member
    Got it. Had to pull the triple tree. No shortcuts there.
