94-96 Wiring diagram question- location of rectifier?
Discussion in '3rd & 4th Generation 1990-1997' started by RedMenace, Aug 5, 2016.
  1. RedMenace
    RedMenace New Member
    DRC, the Congo
    1996 = 28000 miles finally replacing Regulator. New, Honda OEM one is finned and looks great.
    Here's my question:
    On Parts diagram from BikeBandit:
    http://www.bikebandit.com/oem-parts/1996-honda-interceptor-750-vfr750f/o/m151491#sch9338
    Part number 13 is the regulator, and part number 14 is a rectifier. The diagram shows it floating at the front of the wiring harness. I bought it because I thought it was part of the regulator/rectifier system. It is a little black plug with 3 blades. Small, only a centimeter square.
    Where does that thing go? Is it under the dash? Next to the fuse box? Near the battery/main power connection?
    I searched R/R forever on this site. There are so many different threads that I can't find my information in the haystack.
  2. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    I believe it is the clutch diode, which is not part of the charging system.
  3. Allyance
    Allyance Insider
    Germany
    East Bay, California
    It is for clutch switch, to prevent voltage getting to the neutral indicator. Diodes are technically rectifiers. The finned R/R is a full wave rectifer and voltage regulator in one housing.
  4. V4toTour
    V4toTour New Member
    If you bought a new OEM, return it and get a new MOSFET unit. I'm running 40K + on mine. Based on the numerous posts here, 25k, if that, is about all you'll squeeze out of the old OEM units.
    As stated the regulator is combined with the rectifier on bikes since the 80's.
  5. RedMenace
    DRC, the Congo
    Alright. A little confusing on the wiring diagram.
    How about the location? Now, that I bought the part, I wouldn't mind installing it. Is it up under the dash? Hard location to see.
  6. V4toTour
    V4toTour New Member
    Regulator/rectifier lives under the tail plastic on the left hand side. Mounted to the subframe. Remove the seat and tail cowl.
  7. RedMenace
    DRC, the Congo
    Thanks for contributing, but I'm past the R/R. (on the bike and running great!)
    I'm asking about part number 14, the baby rectifier that the boys are telling me is for the clutch switch/indicator. (?)
    Check out the OP for a little more detail, if you are interested in the mystery.
    Beautiful Sunday in Northern Illinois! Going for a long-ass ride.
  8. karazy
    karazy New Member
    If you have the VFR service manual, it's item 19 on page 1-34. If you don't have it, you can dl it from this site.
  9. richierex
    richierex New Member
    Its up on the right side near the fusebox just taped to the loom. You would need to remove the top fairing and then its pretty obvious
  10. RedMenace
    DRC, the Congo
    Loathe to remove the front fairing. Will just hold it until the day comes when it is off for another reason.
