93 "crack, snap and pop"
Discussion in '3rd & 4th Generation 1990-1997' started by dinenoj, Dec 6, 2009.
  1. dinenoj
    dinenoj New Member
    Hello,
    At cold start up just as the motor fire up it will idle for a short while (sounds good) and then a very loud "Crack/Snap" sound. since the motor sounds good before the "crack snap and pop" I don't think it is any ring issues, valves, bearings or transmission. If the motor is already warmed up it does not make the sound as much. I have been shutting it down immediately for fear of something very bad and a possible "lock up" at speed. So if anyone hear has heard of this, let me know.
    Could it be the starter clutch gone bad?
    Bike is a 93 VFR with 1950 miles, but has been in storage for twelve(12) years. Just did a total carb/jet cleaning, de rust/POR15 the tank, fuel lines, filters, all new fluids, battery and new tires (old tires became ABS plastic).
    Thanks all
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    There is no hope for the bike. Lucky for you I am willing to take her off your hands so that you don't have to deal with the problem. :biggrin:
    Where exactly do you hear the sounds coming from? Is it an engine related sound or an exhaust backfire? Sorry to say but your description is a little vague and we need a few more details. The first step is to narrow down where the sounds is coming from.
    Hopefully you can get this sorted since that bike is practically a museum piece with those low miles.
    Regards,
    Rollin
  3. squirrelman
    could be cracked starter clutch, yes.......
  4. dinenoj
    dinenoj New Member
    Maybe I should just unload this bike..... but I can't, it's that awesome:biggrin:
    This sound is definitely an engine mechanical related sound, not just a back fire or timing thing. It sounds like a spinning gear suddenly making contact with a non spinning gear and the "teeth" not matching up.
    If the starter clutch is cracked, what should I be looking for once I drain the oil and take the right side clutch cover off?....
  5. TOE CUTTER
  6. tinkerinWstuff
    hrm... interesting....
    My '85 500 has an intermittent ticking sound when started up dead cold. Intermittent as in it isn't consistent like a valve. I've wondered if it could have been timing chain somehow but I've had the top end apart recently and the chain was good. Besides that, a chain slapping around would have self destructed by now.
    The ticking goes away at 3000rpm (while cold) or once the bike gets a little warmth in her. I'm assuming this could be the same thing on my bike? Anyone know what the life expectancy would be from intermittent tick to snap-crackle-pop like the OP describes?
  7. dinenoj
    dinenoj New Member
    "Crack, snap and pop" and I mean POP
    Some bad news, after draining the oil (which had a slight gasoline smell?),removing the right side cover and the starter clutch (which did have a small crack) I looked deeper into the cases with a flash light and AUGH! I saw a hanging connecting rod. I now know what that awful sound was. At preparing a motor that has been in storage for 12 years, I must not have lubed up the cylinder walls enough. Took off the four spark plugs and it appears to only be the right side vertical "rear" cylinder that is at fault. With the connecting rod flapping around in there I am concerned that more damage may have happened (piston, valves, engine case, etc.). What years are interchangeable?
    '90,'91,'93. Does anyone have a motor lying around? Seriously, not sure what my next steps are, any advise would be helpful at this time?
  8. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Watch e-bay brother, engines do show up.
    BZ
  9. betarace
    betarace New Member
    Middleburg, VA
  10. Nailer45
    Nailer45 New Member
    Herrin,,ILLINOIS
    find a motorcycle salvage yard in your area and you might be able to buy a totaled bike with motor cheap.
  11. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    The ticking of a VF500 engine is normal. This is most likely from the cam chains and/or tensioners but is not the same issue as the larger VF's. Your sound poses no problem and if it's like the other VF500's it will not get worse.
    Actually, I'd say you've found the reason it was in storage for 12 years. My guess would be that the rod went from abuse and/or improper break-in and that's why it was parked.
  12. dinenoj
    dinenoj New Member
    Thanks to all the ideas about finding a new motor, ebay, salvage all are on my list of options.
    When I put the VFR into storage 12 years ago it was running great, and I tend to do engine break-ins by the book but unfortunately it was not prepared for storage thinking I was going to visit it and do start-ups every now and then. Well, I didn't. This past month I have been cleaning out carbs, lubing cables, de-rusted the tank,fuel lines are new with a new fuel filter, air filter and spark plugs. Knowing it had been sitting for a very long time I put some oil down the spark plug holes and hand cranked the engine to help loosen the pistons if they needed to be. Next was to do a carb sync but she started and seemed to run fine (considering). A week later I went to start her up for a test run and "Bang, Snap, Pop" then nothing, thought I had a dead battery so I pressed the starter again and again and it started but with an occasional crack, snap, pop and thats when I thought it might just be the starter clutch.
  13. dinenoj
    dinenoj New Member
    Quick question. Is a 1996 motor a direct install on a 1993 VFR750F?
    Could I install my heads, side covers water pump, carburetors, etc. on this engine?
    thanks again everyone
  14. squirrelman
    IT's a real strange thing whatever went wrong.
    Could you describe where the rod broke, top, middle or botton at the crank??
    Photo would be helpful if you can.
  15. steven113
    steven113 New Member
    Pensacola FL
    That sucks!!! Happened to me also with my 5th gen... With mine one of the nuts that hold the connecting rod to the crank completely vibrated off and then snaped the other side off throwing the rod through my lower case. I was in much the same situation as you except my bike was a wrecked project bike I bought for $500 to fix up and the main reason I bought it was that the motor only had 6K on the odomiter. I was super pissed and almost scraped the project. Luckly I found a good used motor on ebay and went through with the build and I am glad I did. Going that deep into your bike gives you a chance to fix everything:thumbsup:
  16. 15dollar
    15dollar New Member
    Conroe, Texas
    Wow! My noise is not near as scary as yours! I have a strange noise at start up, too. Mine happens every time I start, regardless of temp or prior use. The bike starts, idles for about 20 - 30 seconds, then I hear two clicks. The motor always sounds the same and I have no concerns of internal damage. It sounds to me like a relay turning off. Any ideas what this might be.
  17. dinenoj
    dinenoj New Member
    Squirrelman, the con-rod is broken off about an inch up from the crank shaft. (I tried to photograph this put the flash would get block by the case. I'll try again next time) It looks pretty chewed up, cannot see the other half but I assume it's still with the piston and pin. The bearing seems to still be in place because the remaining rod still rotates smoothly about the crank.
    Their was small bits of aluminum I removed when I took the right side cover off, so I am thinking that the skirt of the piston is all messed up and probably some of the case. Now I'm hoping that the connecting rod didn't crack the case somewhere, or push the piston up into the valves and do more damage.
    I am planning on finding a used motor, and when I do I will open everything up and see the extent of damage. If the heads are OK I may put my heads on the used cylinder and cases. What years of this design is an easy engine swap? I think it's '90-'97.
    Steven113, yes I may do the same thing, except I may throw the used motor in so I have my ride back, then take my time with my original motor and build it up the way it should be, not to mention learning something new, any pointers or advice would be helpful. thanks again
  18. steven113
    Pensacola FL
    I am not sure with your year model what will fit other than not anything newer than 97 will not for sure. I am sure some of the 3rd and 4th gen guys would know the answer to your question.
  19. Jimtt
    Jimtt New Member
    Chicago area
    A fourth gen engine will fit.
  20. squirrelman
    STRANGE the rod broke at a very strong location, near the crank.
    Something catastrophic must have happened to cause it, like a dropped valve......?
