93 750 rear head on a 91 750?
Discussion in '3rd & 4th Generation 1990-1997' started by CruisnGrrl, May 6, 2010.
Tags:
  1. CruisnGrrl
    CruisnGrrl New Member
    ontario, canada
    the previous owner either didn't tighten the plug enough or over tighened it and now the threads are stripped in my #1 (left rear) cylinder. I know they are the same generation. I'm looking for a better fix than a timesert or helicoil. for what i suspect would cost to do a helicoil i may as well replace the head.
    so can i put a 93 750 head on the 91 750?
  2. adamjenkins
    adamjenkins New Member
    Massachusetts
    Yes....................
  3. TOE CUTTER
    Yes you can and that is the way to go, a bummer but you will sleep better when done.
  4. CruisnGrrl
    ontario, canada
  5. betarace
    betarace New Member
    Middleburg, VA
    +1 90-93 all are identical. I see heads on ebay all the time, should be easy to find one
  6. adamjenkins
    Massachusetts
    Not bad 50 bucks....
