91 VFR750 gauge issues
Discussion in 'Mechanics Garage' started by John carnahan, Nov 4, 2018.
  1. John carnahan
    John carnahan New Member
    Springfield, WV
    I've now put over 1000 miles on my new $350 VFR750(initial price). It now runs fine but not quite everything works. The following don't work. Fuel gauge, Temp. gauge, neutral light, kick stand light* and front brake light. I suspect the front brake light is unrelated to the others?
    I plan to run down all of them but my question is, Could any of them be related? Like maybe a common connector? Or should I try to run them down one at a time?
    Of coarse first priority is the front brake light. I confess I don't always use the rear brake but now always do since finding that the front brake light doesn't work. Fixing it is a must.
    *BTW, the kick stand switch killing the engine does work only the light doesn't
    Frankly the inop. fuel and temp gauges don't bother me as my SV doesn't have them and the no neutral light isn't a big deal.
    OTOH I don't really need two bikes and may sell the VFR since it's worth more than the old high millage SV650 and I've discovered that while I like the added zip of the VFR at 72 I can no longer effectively use it.... If I do decide to sell the VFR I'd like everything working.
    Thanks,
    Jack
    test front brake switch by touching the 2 switch wires together with key on. check fuses and bulbs. o_O
    one fuse controls many indicator lights.
  3. John carnahan
    Springfield, WV
    Thanks. Jack
  4. John carnahan
    Springfield, WV
    Finally got back to it. Fuses ok. Front brake light switch was bad. I popped it apart and messed with it for way too long. It would work and quit. Ordered a new one. Need to run them down one at a time. Next is oil pressure.......
    Later, Jack
  5. squirrelman
    read FSM for gauge testing procedure.
