91 vfr upgraded headlight bulbs
Discussion in 'Mechanics Garage' started by crotch fire rocket, Apr 19, 2010.
  1. crotch fire rocket
    crotch fire rocket New Member
    st.paul mn
    can my charging system handle upgrading from the oem 45w bulbs to 55/65w bulbs
  2. safetypro10
    safetypro10 New Member
    Dallas, TX
    Maybe, depending on the total amp load on your stator with all else considered.
    I found the best switch was to Silverstars with adapters for the H4 bulbs. Brighter and better frequency.
    Larry
  3. crotch fire rocket
    st.paul mn
    actually the silverstars are the ones i picked up. I had to slightly modify the three tabs. The reason i was asking if my charging system could handle it was because My r/r failed. I read read now that the factory r/r unites are garbage. I just bought one on ebay last night. I got one with the cooling system. I may also install a small fan if i run into overheating probs
