91' VFR fuel and heat gauge not working
Discussion in 'Mechanics Garage' started by Cheif, Oct 5, 2014.
  1. Cheif
    Cheif New Member
    SOOOO I got a non running bike about 2 weeks ago. I changed all the fuses (because the come in like 10 packs anyway and they're cheap)
    And my bike runs. The tach works the spedo doesn't, but I know why.
    Basically is there any common problems with the fuel/heat gauges?
  2. rjgti
    rjgti New Member
    regina sk
    could be unplugged
  3. Cheif
    Cheif New Member
    Ok fired up today heat gauge works for some reason. do you know around what temp the radiator fan fires up? I had the heat gauge at around 75% and no fan. Is that normal?
    I have it plugged in yes. I'm gonna fill her up a bit and see if that's the case. Also with your vfr if you put your ear down close to the clutch case does it make a faint faint faint clicking sound.
