91 VFR 750 gas leak from carburator????
Discussion in 'Mechanics Garage' started by zaximus, Sep 25, 2008.
  1. zaximus
    zaximus New Member
    Austin , Tx
    I see it dripping right off the carb, one drop about every 45 seconds, it did this before and i took it all apart and cleaned it, and it went away. Seems like this happens after my bike sits for a month or two waiting to be fixed.
    Anyone know why??? or what may fix this???:confused:
  2. powderrecon
    powderrecon New Member
    Seattle
    Did you use new orings, or existing?
  3. safetypro10
    safetypro10 New Member
    Dallas, TX
    Leaks
    Ditto the above plus check float level, either stuck or misadjusted too high.
    Larry
  4. zaximus
    zaximus New Member
    Austin , Tx
    I used the existing orings, they looked like they were in good shape, its probably worth replacing though. How would i tell if the float level is too high?
  5. squirrelman
    VERY typical storage problems
    fuel dripping would be one sign
    or not running right on one cylinder
    in hotter storage regions the float bowl gaskets can shrink and dry, causing slow leaks on initial running, but exposure to fresh fuel and full engine heat usually fixes the leak......
    also caused by sticky floats or dirty float valves, common if there is rust in the fuel tank.
    sometimes clears up with some use.
