8th Gen VRF800F tail tidy Milled Aluminum
Discussion in 'Gear & Accessories' started by Greg800f, Jul 4, 2020.
  1. Greg800f
    Greg800f New Member
    Hi All,
    I have had my VFR800F now for a year and couldn't find a good tail tidy but thankfully I work in an engineering company, so my mate John helped out and CAD it as an Ali block tapped and threaded to make a perfect one and then one of my good CNC friend (Props to you Beth!) helped out and put it through the machine.
    The result is brilliant and I wanted to share it with you guys!
    Let me know what you think!
    And before you asked, yes I could do some again but it would be very expansive due to the fact that it has to spend 3 hours on a CNC machine plus operator cost!
  2. Greg800f
    Greg800f New Member
  3. Greg800f
    Greg800f New Member
  4. Greg800f
    Greg800f New Member
  5. Greg800f
    Greg800f New Member
    You gotta love engineer sense of humour!
  6. Greg800f
    Greg800f New Member
    The unbolt the plate holder, and cut at the red line, not higher so the step still fit into top plastic mount, beltsand it flat or smooth it anyway you can
  7. Greg800f
    Greg800f New Member
  8. Greg800f
    Greg800f New Member
  9. Greg800f
    Greg800f New Member
    When you take off the plater holder, you have to unscrew the square red rear reflector, that's the hole you see in the picture above, use that hole to center the tail tidy plate then, once centered and leveled, bore two holes to fix the tail tidy on. I used stainless steel M8 button socket head for for weather resistance and nyloc nuts on the other side to keep it in place without having to worry about vibration shaking it off.
  10. Greg800f
    Greg800f New Member
  11. Greg800f
    Greg800f New Member
  12. Greg800f
    Greg800f New Member
    IMG_20200702_171147.jpg so much better than that long plate holder!
  13. Greg800f
    Greg800f New Member
  14. Greg800f
    Greg800f New Member
  15. Greg800f
    Greg800f New Member
    That's it! so much cleaner looks for the bike, really happy with it! Let me know what you think!!
    Greg
    Ronsk likes this.
  16. mello dude
    Great job!
  17. rhoderage
    rhoderage New Member
    Nova Scotia
    Agree, looks great... some thought, skill, and access to tools end up with a nice professional result
  18. Greg800f
    Greg800f New Member
    Thanks guys!! Just need to get that swing arm painted black or carbon wrapped and the bike will be done!
  19. Jen
    Jen New Member
    Looks very nice, I'm sure it took a lot of work. This 007plate carbon fiber fender eliminator / plate hider is not bad:
